The ACCURA 1 is a robust yet sophisticated handheld electronic tyre inflator designed to break the mould of existing handheld tyre inflation. With leading electronics and sensor technology as well as patented software algorithms it offers fast, accurate and trouble-free tyre inflation and deflation.
Its biomorphic handle and direct valve mechanism enable the operator to deliver excellent rates of inflation in comfort, which in turn provides customers with extended tyre life, increased fuel economy and improved safety.
Suitable for tyreshops, garages, car dealers and transport depots, ACCURA 1 is widely accepted as the best product available for measuring and checking digital Tyre Pressure Monitoring Systems (TPMS).
Key Benefits
- Reduced usage times - driven by the simplicity of use and clear display
- Reduced operating costs - fast inflation and deflation rates
- Increased customer service - high levels of speed, accuracy and safety
- Reduced cost of ownership - long product life
- High versatility - flexible usage
- Guaranteed accuracy - individual testing
- Reduced tyre wear extending tyre life
- Increased fuel economy
- Increased safety and reduced tyre-related incidents
Key Features
- Robust electronic design
- Ceramic sensor
- Clear and easy to read digital display
- Modern, lightweight and shock resistant construction
- Proprietary software increasing accuracy, fine metering and eliminating the chance of false readings
- Direct valve design increasing inflation and deflation rates
- Individual tested and certified
- Built in swivel and hanging device
- Over-pressure warning if pressure exceeds 12bar / 174psi / 1200kPa
- Long battery life
- Low battery warning light
- Bar, psi and kPa calibrations and range of accessories
Specifications
Accuracy : Exceeds EC Directive 86/217
Reading Accuracy : 0.01bar / 0.2psi / 1kPa
Maximum Inlet Pressure : 15 bar / 218psi / 1200kPa
Inflation flow : 910 l/min @ 13bar supply
Approvals
German: PTB 18.08/06.04
Product Options
| Product No. | Description | Hose Length | Tyre Valve Connector | Calibration |
| DAC1A03 | 21" General Model | 0.53m (21") | Twin hold-on | 0-174 psi |
| DAC1A06 | 9ft Tyreshop Model | 2.7m (9ft) | Twin clip-on | 0-174 psi |
| DAC1A08 | 6ft Tyreshop Model | 1.8m (6ft) | Euro clip-on | 0-174 psi |
| DAC1C03 | 21" General Model | 0.53m (21") | Twin hold-on | 0-12 bar |
| DAC1C06 | 9ft Tyreshop Model | 2.7m (9ft) | Twin clip-on | 0-12 bar |
| DAC1C08 | 6ft Tyreshop Model | 1.8m (6ft) | Euro clip-on | 0-12 bar |
| DAC1D03 | 21" General Model | 0.53m (21") | Twin hold-on | 0-1200 kPa |
| DAC1D06 | 9ft Tyreshop Model | 2.7m (9ft) | Twin clip-on | 0-1200 kPa |
| DAC1D08 | 6ft Tyreshop Model | 1.8m (6ft) | Euro clip-on | 0-1200 kPa |
