PCL's exciting and innovative ACCURA range of "menu-driven" forecourt units is now an established brand throughout the world.
Suitable for petrol filling stations, the electronic preset units capture new digital technology in a modern, aesthetic design, offering repeatable accuracy and reduced maintenance and lifestyle costs.
The easy-to-use ACCURA range includes wall-mounted and pedestal units, and a forecourt self-contained unit with retractable air and water reels.
All use auto-start inflation and default to safe setting, and provide the user with higher safety, increased fuel economy, and extended tyre life.
Units can be customised to suit corporate image and language.
Key Benefits
- Consistent cost effective provision of high levels of safe air inflation services
- Strong marketing potential with modern design, bespoke graphics and user friendly air provision
- Long life time costs - long product life with robust design and proven electronics
- Low and simple maintenance with excellent diagnostics
- Customisation to meet individual needs and applications
- Guaranteed accuracy with individual testing
- Reduced tyre wear extending tyre life
- Increased fuel economy
- Increased safety and reduced tyre-related incidents
Key Features
- Electronic pressure preset
- Auto start inflation
- Clear display for easy customer usage
- Default to safe-setting
- Robust, high reliability and modern design with die-cast aluminium housing
- Ceramic sensor - accuracy to +/-0.5% of full scale reading
- Attractive and durable membrane with customisable graphics
- 230v, 100/120v and 12v versions
- Can inflate accurately with hoses up to 50m
- Comprehensive diagnostics and error reporting
- Wall or pedestal mounting
Specifications
Accuracy : Exceeds EC Directive 86/217 (to +/-0.5% of
full scale reading)
Reading Accuracy : 0.1bar / 1psi / 1kPa / 0.1kg/cm²
Maximum Inlet Pressure : 16bar / 232psi / 1600kPa / 16.3kg/cm²
Inflation flow : 400 l/min @ 10bar supply
Product Options
| Product No. | Description | Hose Length | Tyre Valve Connector | Calibration |
| A10S20T | Analogue Forecourt Model | 7.6m | Twin hold-on | 0-140 psi & 0-10 bar |
| A20S20T | Analogue Forecourt Pedestal Model | 7.6m | Twin hold-on | 0-140 psi & 0-10 bar |
